TurboBuickSix
- May 23, 2001
Well if you had at least 10 inches of vacuum in the booster when you could'nt stop, then a pump might not improve it at all.I would go over the whole system and try to find a problem,maybe you have air in a brake line.You might be able to find a booster that does not need as much vacuum as your current one.Put a mighty vac tester on the booster with the check valve inline and test it and make sure the valve only allows vac and not pressure going to the booster.It should have vacuum in it when you take the valve from out of the booster.
