oohhh yea, I built everything to really good tollerances, and compression is 9.5 so I can turbo it later...
welcome to the turbo buick world. i love your motor i use to have that setup but converted over to the drawthru turbo.
The fuel tank needs to vent, besides just a vented gas cap. Perhaps just put a small pcv breather on it.
Hey guys, I took the charcoal canister out the other night, is it safe to plug off the line to the tank to keep fumes from floating out?
That's something I would not remove. The vented gas from the tank and carb bowl is stored there. There's a chapter in 'Rochester Carbs' dedicated to it. Study it and make it functional again. It saves gas and helps the enviroment. The canister system is the one emissions system that is actually good for our cars. It probably does'nt work right now once you starts to butcher vac lines. I can probably post a simple drawing on how to make it work again later. :smile:
Hope you can see this, (this forum limits everything).
