It seems that the valves in my right cylinder head are damaged. Compression tests were run, and oil was added, but the compression didnt increase.
This is what i have for readings (not sure if the numbers on the cylinders are correct...):
From front:
L R
1:145 4:150
2:140 5: 75
3:140-145 6:105
As you can see, the 5, and 6 cylinders are the problems, and since we added oil and no change in compression was seen, im thinking its the valves.....
Now If i am correct its the valves, should i re-seat them myself, or have a shop do it?
From front:
1:145 4:150
2:140 5: 75
3:140-145 6:105
