There has been alot of tech advise here on the boards about which valvespring to install on your car for an upgrade to the oem cam/lifters/etc... The CompCam 979-12 or 980-12 seem to have been the standard over the years. There has also been the discussion on re-installing the oem cup dampner that surrounds the spring, or not. And whether to run the internal dampner that comes in the 980-12, or not. Here is some information based off of measurements using an Intercomp digital spring tester. Thanks to Richard Clark for the use of his equipment & Patrick (SloGN) for doing the dirty work... :biggrin:
A couple givens:
The factory installed height on both GN and TTA heads, using the oem locks/retainers/valves is 1.687". If you choose to install the new springs without the oem cup dampner that surrounds the springs, which also acts to shim the springs .040", your new installed height is 1.727". The stock oem camshaft measures .393"/.408" lift, which I averaged to .400" for this "testing".
We measured (2) different CompCam 980 springs out of a brand new pack.
Spring A - Height - Spring B with internal dampner:
78 = @ 1.727" = 76.2
88.8 = @ 1.687" = 87
202 = @ 1.327" = 199.6
217.6 = @ 1.287" = 211
Spring A - Height - Spring B without internal dampner:
71 = @ 1.727" = 72.4
81 = @ 1.687" = 83.2
181.6 = @ 1.327" = 183.2
193 = @1.287" = 194.2
For comparison sake, here are what some stock oem springs with 109k miles off a TTA measured:
55.6 @ 1.727"
65.6 @ 1.687"
164.2 @ 1.327"
174.4 @ 1.287"
K.
A couple givens:
55.6 @ 1.727"
65.6 @ 1.687"
164.2 @ 1.327"
174.4 @ 1.287"
K.
