100# valve springs & oil...
I was talking with John Pearcy the other day while ordering some new valve guides/seals to replace while I was doing my valve springs. He told me to run "RACING OIL" only from now on. Here is part of our e-mail conversation...
John,
Just ordered some valve cover grommets and new valve seals for my TTA. I'm planning on changing my springs in the next week or so…would like to do them this coming weekend and figured with 46K on the car I should probably change them while it is apart. Will the parts get to me by Friday if not what would it cost to bump up the shipping some.
Do I need to do anything special to install the valve seals? I have never done them before but have done valve springs…looks like you just pick them out and then slide the new ones in before the new springs go in or is there more to it then that ?
Thanks, Scott
Scott,
Seals are easy. The seals come with a sleeve, the sleeve goes over the valve steam so the seal can slide over the keeper groove. This prevents the seal from getting a tear in it from the shape edge of the keeper groove. The sleeve is long, so you want to get some of the length off at least 1/4" or so past the groove.
In case you didn't know, use only racing type oil from now on. It has all the phosphorus and zinc in it to keep the cam lobes from going flat. Newer oils removed it all to help the Cat's last the 100,000 warranty.John
John,
About the oil...all I run is 10w30 Mobil 1...I though that was what I should be using? If not what brand and weight do you recommend? I don't drive the car in the winter unless it is real nice...like in the high 50's or 60's and only put about 500 or so on the car over the Summer.
Thanks, Scott
Scott,
Nope, can't use Mobil 1 anymore, they removed all the phosphorus and zinc from it. It's only good for roller cams. I don't have any rec's on oil, just get a brand that's specifically say's it's formulated for racing.
Comp cam's told me Quaker State Gold was one brand. Stay with 10w30.
John
I guess this explains why some cams are getting wiped ?
So now the question is what Racing Oil should I be using...I noticed Royal Purple did not carry a 10w30 on a 10w40 ?
-Scott
