dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
i just got my heads done and come to find out my vavle springs are junk what are some good springs for a stock cam ???
SignUp Now!what are some good springs for a stock cam ???
This is all with a stock cam right??? I have some cc980 coming on fri
i have a stock cam and stock springs like you guys! did you guys feel a diffrence or see any gains from swapping out old stock springs to the new springs? supposedly good for 2 tenths at the track?any opinions on this?
how long does it take you guys that are not professionals to do this in the car?
After getting the valve covers off and using some clean rags to block all the holes in the head so you don't loose a keeper down there, I took my time and used the yellow nylon rope in the spark plug hole to hold the valve up, about 2 hrs a side. I used the kirbans valve spring tool.
Tarey
No need to replace retainers or locks/keepers
In gm high tech performance magazine a few years ago they said replacing your worn valve springs was worn 2 tenths in the quarter mile. Can anybody back that up?
The reason i ask is i am not a mechanic and i work slow but i am sure i can do this but it will take me several hours but if it is worth 2 tenths i will do it otherwise the valve springs from 1987 will stay in there.
