Apr 13, 2002 #1 F Four-Four-Two Guest I've heard a lot of talk about replacing the factory valve springs. When is this needed?
Apr 13, 2002 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,019 Probably about 8 years or so ago for your car. Stockers don't last too long and are nowhere near the rated spec. over time. My old ones I took off this year measured 60-66lb.s. Spec. is ~80. 112K and 135K. Worth doing in MHO.
Apr 13, 2002 #3 F Four-Four-Two Guest Mines got 38k on it, so I wasn't sure if it needed it or not. Good idea then?
Apr 14, 2002 #5 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,019 It also has 15 years on it. If you would like me to check one of your original ones, after you replace them, I can do it at work here. We have a very accurate machine to do it. I was glad I got rid of mine, should have done it years ago.
