turbov6joe
Signal 1 J-12
- May 22, 2002
What is the stock rocker arm ratio for the TTA heads?
What size is the rocker arm stud??
What diameter and length are the stock TTA pushrods???
What do y'all recommend for an aftermarket roller rocker (including ratio), pushrod, and guideplate for the TTA's????
Is is a royal PITA to change the valve springs with the motor in the car?????
Lastly, what kind of job is it to R&R the rear main seal while the engine is still in the car??????
TIA
TIA
