opeltwinturbo
- May 26, 2001
At BG last week I made 1/2 pass. This was the first pass of the year and it was a granny launch and a mild pass. About 1/2 track it sounded like a gravel mixer. With the motor still running (good oil pz) I pulled the car over to the side along the wall and coasted to a stop on the first exit road Car was towed to the pits and we tried to refire it. Zero compression on all cylinders. Pulled the valve covers, all rockers seemed OK. Pulled the rocker shaft and all push rods were straight. Pulled down the headers and saw all exhaust valve guides broken. Pulled the heads and the six pistons had valve circles on the deck. Valves smacked the pistons. Pulled the front cover to check possible keyway broken. All tight. Idler good. Ironically, timing marks were dead on. Pulled the distributor and it sounded like a castinet. The rotor cap had broken all around the perimeter of the counterweights. Gears on distributor looked fine. Rev limiter was set at eight thousand. Since it was a warm up run I did not have the laptop in the car. Shiftnoid set at 7500. I do not think I winged the motor. Valves were at 20 & 22. Any thoughts on this.
Secondly, now that the valves are toast, should I go with titanium or stainless. I have two sets with titanium and one with stainless. Also, your thoughts on this.
John
John
