- Jun 18, 2001
Ok, searched a bunch, didn't find much with as much specificity as I'd hoped.
I'm doing a hydraulic roller cam on my engine, I've mocked up the engine with some 8723PT1's I had laying around. This block and heads have been decked a couple of times, so the measurements obviously aren't stock anymore.
My pushrod measurement is 7.980" with the 8723PT1 head gasket, which I've measured at .050" thickness.
Now, there is no 7.980" pushrod I can find anywhere. I can find 7.975, 7.990, and 8.000. I checked Summit and Smith Brothers.
Here's the wrinkle, I'll be putting Cometic MLS gaskets on this thing when it goes together for real, the .027" thick ones. They're just not here yet, and I was bored so I mocked it up and measured. Subtracting the .023" difference between the 8723PT1 and the Cometic from the measured length gets me to a 7.957" rod.
How much longer than the measured rod can I go before the lifter starts pushing the valve open? The lifters themselves have 0.120" total travel in them. I measured with the lifter fully extended, no depression. Obviously I don't want to go anywhere near that, but can I get away with a 7.975" length rod?
Or do I need to just bolt it together with the right head gaskets, measure again, and stop trying to math it out?
