Various race parts
turbobuick
Staff member
CAS Sheetmetal Intake complete with fuel rails $750
Weldon 2025 pump with weldon regulator $600
Classic FAST with practically NEW WB02 have splice harness and stand alone, bank to bank setup for IPU ignition (distributor not C3I) $850
More to come as I do spring cleaning!
More parts
TA heads, pretty much new ran with VERY low run time before coming back off the motor. They are hand ported by TA performance and perform very well on the flow bench. I had them inspected and had to sleeve the center bolt holes as the head porter ground though and didn't sleeve them which is typically done. I also had them flowed and spring pressures checked, they are solid roller springs. The heads are complete and have all top of the line parts. Include 1.75 shaft mount T&D rockers, heads studs and pushrods. $2900, you would have over $4k into these to duplicate them and these heads are pretty much new.
MSD crank trigger complete set up wheel pick up bracket etc. Tough to find $200
Interested in the CAS sheetmetal intake.Is this only good for high boost &
RPM to make power?How would it work for a street car with champion cnc
irons,GT6152E turbo,Atr headers & 3" DP,210/210 cam,32-3400 stall NL
converter,3.42 gearing?Let me know.
John
John
We changed it out because it is a more street oriented design. It would actually work pretty good with that setup except you need to have an on center stage 2 block for the intake to fit.
All parts including TA heads will be at Bowling Green this weekend
Sorry it is sold along with the intake and fuel pump.
FAST is available
TA Heads are still available
