quickstrike
- Jun 4, 2002
First off I have read many of the old posts concerning high VE numbers. I understand the relationship they have with air and the efficiency of the motor at a given volume.
I also understand how the ECU will use these numbers along with the target A/F numbers(both open and closed loop) to calculate an inj pulse width, that will be close to the desired result.
I have SD 83lb injectors they have not been flow tested. My setup parameters are all correct and 83 is the value entered for lb per hour. Duty cycle is around 50%.
My concern is that my VE numbers are very high. In the 120 range. I am running 14psi supercharged. Fuel pressure has been verified to be at 45(static) and does increase the proper amount under boost. Rails, lines, pump, etc.........is plenty(up to about 1000HP) I am only in the 650 range, maybe 750 if you count the 100HP loss from driving the charger itself.
How much off the mark would the injector rating have to be, to make my VE numbers so high? 2-3lbs? 5-10lbs? anyone have the same experience as this? Maybe I shouldnt even worry that the numbers are so high, but this seems a little excessive.
I would appreciate any thoughts on this. Thank you in advance.
Randy
Randy
