How much does the vehicle's weight come into play with the stall of a converter?
I have a hybrid that weighs 2800 lbs, now given the same engine setup and HP in a 3800lb car, would the converter stall and behave the same?
I guess I'm trying to figure out, with less load would you need a higher stall rating?
Much like when rating the stall of a given converter. Less hp =less stall, more hp = higher stall.
Clear as mud?
Paul
1972 Toyota Celica with an 87 GN Engine.
Motor 30 over, 10/10 crank, high vol.oil pump, SpeedPro 194/204 Cam, Comp Cam 980 valve springs, ported and polished heads, PTE 44 turbo, 0.65 Ex housing, Dutweiller Big neck intercooler, Jay Jackson's 62 mm Throttle body, ported and polished plenum with upper part of EGR tower removed, Power Plate, solid MAF pipe, K&N Filter.
Postons headers and 2 pce crossover pipe. Hand made TH style DP, 3" exhaust split to 2 ½ " dual Magnaflows.
52 # Siemens low imp. injectors, Red A's modded ECM, Translator Plus, LT1 MAF (Mounted in the up-pipe) Extender chip, Boost Commander, dual wastegate solenoids, Adj. Fuel Reg, Hot wired Walbro GSS 340 intank fuel pump, Poly Mount.
ATR billet OD H20 pump pulley, FlowKooler water pump, 2 speed Ford Taurus electric fans, RMI 25.
Type II coil pack and module, 8.5 Magnecor's, AC CR42's.
DirectScan, Caspers Knock gauge, Autometer 30/30 boost/vacuum gauge, Autometer tranny temp gauge.
200 4R tranny, B&M 28,000GVW SuperCooler, remote filter, Energy Suspensions Polyurethane mount, stock D5 converter, B&M Megashifter, Chopped Ford 9" @3:25 Trac Lok rear with a 300 ZX disk brake setup. Air bags, 85 Supra 57 mm piston 10" vented rotor front brake setup, Nissan 300 ZX 15/16 master cylinder, Dunlop SP 5000 205/50ZR 15's front SP 8000 245/50/15's rear. Hurst Roll control, Ford power steering rack, Bilstein Rally shocks rear, Tokico race struts front, heavy duty coils.
Clear as mud?
Paul
