UR50SLO
The Reaper
- Jun 12, 2001
Craig or Lance or FAST buick tuners.....
We have not had alot of time but.....
We finaly got the white Camaro out down at Morocco.
The first pass was a 12.42@114mph with a 2.08 60'
The second pass was a 12.02@114 with a 1.94 60'
I dialed in the 02 correction and brought the timing advance to about 36deg below 3500rpm.
The third pass was a 11.51@114mph with a 1.53 60'
We are leaving the line with 3lbs of boost (much more it will push through the lights) we are corecting this right now.
We are building max of 14lbs of boost all the way through 3d gear with 94oct. fuel. O2 Correct of .08
15deg of timing at anything above 3500rpm
I have the Air Fuel Ratio set at 12.0 from 4000 up
What is the leanist we can make it? What is the max boost on 100oct with CAS front mount?
What is the max timing we can use with allum. heads and 100oct?
237CID Buick
GN1heads,Stock rods&Crank, BGC Intake CAS front mount in a 1986 base Camaro approx 3200lbs, Bruce Tolle Trans w/3500 converter,9" ford w/3:89 Gear Custom rear susp. .72mm turbo
HD Actuator (I think that's all the important stuff)
It's running great just looking for tips on max timing,fuel ratio ect to make fine adjustments.
Thanks for your help, Scott~
237CID Buick
