me and buddy have been trying to fine the cause of why i am seeing KR on all the time below 3 volts of TPS and at or around 10lbs of boost. well we decided to pull the act off the puck and see if i still get KR well i dident and the car ran better than it ever has with 0 boost WOT 02's were 832 with 0 KR the whole time over 100mph i have tuned and tuned #'s are in specs of gnttype i ahve new headers and cross pipe new o2 sensor and it reads good new injectors 009's and have tried 2 chips same results i ahve LT1 mass air meter with translater reads like a stock sensor fuel pressure is 38 line off reads with the boost will go over static with power stall at 5lbs, have preformed comp test 145 to 148 on all cylinders, i have done all i can think to do on this car to get rid of the Kr and be able to drive it like it was born to drive (fast!) if anyone could give me some advice or pointers would be very thankful. TIA
turbotoyz!
turbotoyz!
