I have a Viper 791XV installed.
I have two remotes and they're both doing the same thing.
When I arm the alarm, I see the "transmit indicator" symbol, I hear three chirps from the remote, and one chirp from the car. The lock/unlock status never changes, it always shows unlocked and the"receive indicator" symbol flashes every few seconds on both remotes. When I press the unlock/disarm button I hear two chirps from the car and three chirps from the remote. If I leave the hood open or the trunk open and arm the system, it does not show me the "hood" or "trunk" symbols.
But the alarm is active, it will go off if I try to open a door and the trunk release still works too.
I tried to relearn the remotes by doing the following:
Driver door open
IGN to on
Press valet button once, press again and hold
Press disarm/unlock on the remote
I get an audible chirp from the car
IGN to off
Close door
Test alarm and same thing as before (tried it with both remotes, multiple times)
I also disconnected the battery for 10 minutes and tried that as well. No luck, same thing.
I can't imagine both remotes going bad simultaneously. Could a failure in one remote cause this? Is there a way to un-sync the remote completely from the alarm system and try them one at a time? I removed the batteries from the remotes and tried them each separately, but the same thing again.
Owner's Manual: http://dl.owneriq.net/f/f37b0657-47d2-4927-81ab-829a88985afa.pdf
Driver door open
IGN to on
IGN to off
Close door
