...it puts the fuel pump and injectors in an adrenalin rush mode at WOT
Get on a dark road at night, build at least 10-11 lbs of boost (or go WOT) and watch to see if your headlights get noticeably brighter.
I'm running one as insurance...picked it up used for $10...it puts the fuel pump and injectors in an adrenalin rush mode at WOT and keps you fporm leaning out and doing bad things to your motor.
I'll not debate the merits of demerits of using a Volt Booster...Just suffice it to say my car came with one, & I've been using it without any prob'm for 4 yrs, activates at 2.0 TPS voltage minimum (regardless of boost),,, I've since added a Hotwire kit, but have kept it tho for ign coil/spark enhancement also.
I've also since added non-progressive alky--so the voltage "surge" (about 1.5V for me) does not interfere with the typical ramping of alky pump speed--as with progressive kits...
Has anyone one used a volt booster with a progressive alky kit? Why aren't you suppose to use with a alky kit?
