So my volts dropped to 9.9-10 change the alternator still the same a was getting 14volts or so at the alternator andvjust a little less at the battery but between 13-14 volts.before it started acting up but the scanmaster always showed 12volts even though the alternator was putting out alittle over 14.like 14.48. I know you get voltage drop do to wires and travel to the scanmaster.so i a was getting at least 12 volts at the scanmaster i new a was good so long i was getting the 14+at the alternator and battery.the funny thing is car not running i get 12 +volts at the battery and the same at the back of the alternator mybe just little less.then when i turn the car on at the back of the alternator its11 volts same at the alternator and at the scanmaster.9.9-10.....any ideas as always thanks in advance ...ps also the check engine light does come on while cranking then turns off volt ligjt also comes on and off .
