I am trying to run some turbo calculations vs power capabilities.
The engine is hardware capable of 800fwhp. I know the robotic choice is the hpq70, but I am trying to at least take a survey.
Does anyone have any documented, empirical, or educated guess as the volumetric efficiency numbers for the stock 231 as if it was naturally aspirated? All the turbo selection models I have found require a volumetric efficiency for the engine N/A.
Also I have GN1 full race port heads and intake, how much does this increase volumetric efficiency at 14.7pisa? My goal is to move enough air to make 800fwhp. Getting the air required (lbs/min) is easy, same for every engine, but figuring out the pressure ratio…then the density ratio…requires some good estimation of the volumetric efficiency of the engine non-supercharged.
On a stock engine, what rpm does the VE reach its highest point?
The stock engine should provide a base line for me. I can kinda calculate what rpm direction VE will go with different cam choices and such.
P.S. Does Precision release compressor maps on their turbos?
