off subject and you should probably start a new thread ,,
stock chip??160 therm with a stock chip will do little for operating temps , the fans on stock chip wont come on until 190 so no cooling really happens until fan turns on and the stock 22yr old fan may be low on muscle , it can be rewired to run in high mode which might help a little
rad could be neglected and clogged with corrosion too, or even just bugs or leaves
get the temps down and you should be able to run a little more boost
11psi is about right if you have the hose connected turbo to wastegate (no solenoid or bleeder) which will result in lowest boost possible for your wastgate
then again is that a real boost gauge your qouting boost from or the stock indash led liar?
blms say your rich a little not lean so no vac leak unless your way over spec on the fuel pressure , with stock chip thats 37psi vac line off fp regulator-engine running (reconnect vac line after testing )
fact that its reading a little rich on blm would tell me tghe o2 sensor is capable of putting out a high o2 number so i wouldn't assume it to be bad ,
your cc count (look at the SM in CC mode)with stock chip should rise from 0-255 in under 90 seconds at warmed up idle if o2 sensor is good , aftermarket chips like TT run openloop idle and cc wont change much at idle
