Pete Revenidis
- Mar 31, 2013
Not a bad idea
SignUp Now!i have never used them on my cars on the 2 race cars ive built and crew for we use the bf r1 and the hoosier cantalever slicks but a few other guys i know have used them for track days with good results. on my M3 powered 318ti i use the Falken Azenus which for the money are very good but weigh plays a roll on how much grip you end up with my car weighs 2400lb and i can do 15 tracks days on a set the car with the R1's has to be at 2980lb for race rules he will use a set of tires every 2 race weekends so it varies on use and weight on how a tire works and on the driver my car is very light and has alot of power as far as BMW's go and im a jerky driver if i was smoother i could get more out of themWhile we're talking tires...what are your thoughts on the NT05r's?
2 questionsScot w. runs coilovers. He has DSE now, but is switching to ridetech. I also ordered ridetech front coilovers along with their new tru-turn system. Moog seems to be the most common spring replacement. Many run 5658's with 5413's for about a one inch drop. However it has been suggested to me to run 5658 and 6377 for a lighter spring, or 5660 with the 5413 for a heavier spring rate.
Hey Charlie, what would that run if I sent a driving car to you? I figure there is no reason for me to re-invent the wheel. ThanksYou can stiffen the chassis up quite a bit with bolt on parts but if you really want to do it right then you need to pull the frame and do some welding. The seam welds are horrible to put it nicely and the frame is a wet noodle. I had a bad frame on mine and got another to put in it. If you pick one of the rear horns up that side will move about a foot before the other side starts to move.Box the center and then brace the rear cross member up and then you end up with a decent frame.
Depends entirely what you want done Troy. Mine has been boxed and braced quite a bit and probably have 200 hours in it, including cleaning and painting it. Still need to make a new tranny cross member and position the engine where I want it. To pull a frame will take several hours and then the fun starts. If I have a bare frame here I can do all the mods I did on mine for between $1000 and $1500 as a rough estimate but it should be less than that.Hey Charlie, what would that run if I sent a driving car to you? I figure there is no reason for me to re-invent the wheel. Thanks
