Sep 20, 2008 #1 L lenc23 Member Joined Dec 12, 2007 Messages 218 how much boost can you run with the stock waste gate actuator, as opposed to the heavy duty actuator?
Sep 20, 2008 #2 J johnnyttype Active Member Joined Apr 18, 2007 Messages 1,313 lenc23 said: how much boost can you run with the stock waste gate actuator, as opposed to the heavy duty actuator? Click to expand... do you have an adjustable wastegate? if you get a cheap little manual boost controller/bleeder you could get 20+ out of a stocker i suppose. i run mine with adj. wastegate at 16psi and then use my MBC to raise the boost to 22psi. hth
Sep 20, 2008 #3 L lenc23 Member Joined Dec 12, 2007 Messages 218 yes i have an rjc boost controller, but i want to run like 25 lbs and also want stock appearing
Sep 20, 2008 #4 J johnnyttype Active Member Joined Apr 18, 2007 Messages 1,313 lenc23 said: yes i have an rjc boost controller, but i want to run like 25 lbs and also want stock appearing Click to expand... i have the qboost controller and i know it goes 25+psi...just my gauge stops at 25 i guess you could do it just make sure there is no boost creep or spikes when that high
Oct 15, 2008 #5 C ccbrett QUICK 6 Joined Oct 12, 2007 Messages 66 Hey guys where can you get the q boost controller thier website doesnt seem to work anymore.
Oct 15, 2008 #6 J johnnyttype Active Member Joined Apr 18, 2007 Messages 1,313 i got mine from gbodyparts but i didnt see it on their website when i looked.
