waste gate
jimski
In over my head
Need a good used none leaking waste gate please pm me with pictures and prices. thanks
I am also looking for a wastegate and don't have a problem with aftermarket. It's bound to be newer than 1980. My question, as well as part # is, does it need to be a dual port? Is there a significant difference? And with the dual port do you have the plumbing diagram? It's the rear port that I question. Front port, (actuator side) to manifold, vac/pressure. Other port I have to a port on the upper part of the manifold, right under the carb.
You can use a dual port but it really don't matter. Most block the port closest to the turbo anyway. Gpop also can rebuild the stock one from what I've been told by the TTA 301 guys.
