Wastegate Adjustment
jpratt
How hard should it be to pull the actuator when increasing boost? I am running 14PSi now and wanted to increase by 2 full turns, but I cannot pull the arm far enough to go back over the waste gate arm. Should I need pliers or something to pull the rod with?
Yes, you will need pliers. There was even a tool made by one of our vendors which grabs the arm so you can pull it but it in not needed.
Is it set up tuner style? Where the vacuum line runs straight to the wastegate diaphragm? I tried that once and I couldnt believe how slow spoolup was compared to the bleeder setup. That diaphragm isnt designed to take such a huge spring load. Its really easy to tear and start leaking. The fact you have to turn it so far may indicate that yours is torn. With the bleeder setup, I can easily run 20 psi with the arm set just tight enough that the arm slips right over the puck arm with zero effort. If I adjust it so I only have to pull the arm maybe a millimeter to get over the puck arm and then adjust the bleeder, I can get any boost I want with really fast spoolup. It seems with this custom bleeder, turning the wastegate arm doesnt really alter boost much. Maybe 5% of what the bleeder can do. I use a big bleeder valve from Fabco-Air, which is designed for use with large pneumatic cylinders. I can adjust boost so precisely its crazy. Ive used the factory boost solenoid by itself, the solenoid with a pressure regulator, a pressure regulator by itself...lots of combos. Im really happy with this setup I have now. Its all plumbed up like stock, only I use the Fabco bleeder instead of the factory solenoid. It spools really quick. Way faster than tuner style and faster than the stock solenoid. There is a thread I posted showing the pic of my bypass system, as well as a few others. It shows this bleeder. I think the thread is called boost bypass pic or something like that. Do a search if you want to see it.
