- Nov 30, 2009
Is it normal to get more water out the exhaust on start up with E85 than straight gas ?
SignUp Now!Yes,a lot more.Is it normal to get more water out the exhaust on start up with E85 than straight gas ?
Well it helped me find an exhaust leak on my turbo to downpipe mating surface . Water comes out of there like crazy until it warms up , I thought I had a water leak. Thanks , SamYes,a lot more.
It leaked there when you used gasoline,you just never noticed it.Well it helped me find an exhaust leak on my turbo to downpipe mating surface . Water comes out of there like crazy until it warms up , I thought I had a water leak. Thanks , Sam
Your probably right ! What's the best way to seal that flange ? Right now there is only copper spray gasket coating and apparently that isn't working too well .It leaked there when you used gasoline,you just never noticed it.
I've always used silicone,but there's no way to seal the pivot pin of the wastegate puck. There's always a mess that needs to be cleaned up.Your probably right ! What's the best way to seal that flange ? Right now there is only copper spray gasket coating and apparently that isn't working too well .
Wow , my memory is shot !! The leak is at the header to turbo flange , not the down pipe . The header flange DOES have a gasket and still leaks . I used a Vibrant aluminum covered gasket , any suggestions ?I've always used silicone,but there's no way to seal the pivot pin of the wastegate puck. There's always a mess that needs to be cleaned up.
I use silicone there as well. One possible reason for that leak could be that the fasteners are loose.Wow , my memory is shot !! The leak is at the header to turbo flange , not the down pipe . The header flange DOES have a gasket and still leaks . I used a Vibrant aluminum covered gasket , any suggestions ?
