Yea, was looking at frozenboost.com, I am waiting for some additional fab parts to come in for the cooling system ie. shroud and fans, and will probably use their 1200hp kit with upgraded pump, 7" x 26" x 4" heat exchanger with dual 7"fans, and will probably have a custom shroud built for just the heat exchanger. I am also using a Atomic remote mount trans cooler with fan. I am getting a little nervous with all the electric cooling fans on this project. anyone out there running 5 electric fans on the street? All fans will be thermostically(is that a word?) controlled except the two 7" that are located on the heat exchanger for the air to water intercooler which will turn on with the key.
