Vendor Defendor
Out the window
- Nov 25, 2002
My brakes seem to be getting weaker, earlier I was inspecting the power master to see if I saw anything obviously wrong and I noticed around the weather-pack with the three wires on top of the power master (I think thats the pressure switch, not completely sure though) there there seems to be a little bit of fluid around it.
So, if a little fluid is being lost around there can that loose pressure and weaken the brakes? What should I do, replace the switch? or is it possible (assuming that it is screwed in) to put teflon tape around the threads?
