Ok guys... update. Tonight I pulled the valve cover off the car. Valvetrain looked pretty good. All the springs seemed to be about the same height. No excessive play in lash... just some side to side play on rockers. Tips of rockers all have same wear pattern.
I then bumped motor over and brought # 6 to top dead center. Looked in the spark plug bore at top of piston. There wasn't even a mark where the spark plug would have come in contact. Weird but ok...
I then move on to oil pan. Drain oil and drop pan. Rotate motor until # 6 is at BDC. Check thrust... matches all other ones. Look at piston, no holes. I then removed rod cap. Bearing is perfect and babit is all intact.
On a negative note, I did find metal shardes sitting in head galleys where intake head bolts are. I am talking some of these shardes were pretty big. Not sure where that shit came from.
So, now my thought is should I rip apart the top of the motor and see whats going on? Double check heads and verify that valves are seated? Could the metal shardes be from the cam lobes? If valves are ok and piston is good, what the hell crushed the plug tip into the electrode?
Looking forward to your thoughts gents...
BTW, what is rod cap torque spec?
Chris
