Evaddave 87gn
Always learning...
- Dec 16, 2005
Put some plugs in and start it up.![]()
Agree....
sweet! Looks like you might have dodged the bulletHa! You guys rock! Thats my plan. Compression test.resulted in all cylinders being the same. I bore scoped all 6 cylinders and they all look good. Got the valve cover, the downpipe, the oil pan, and plugs and wires back on. Gonna finish up putting my uppipe and crossover pipe on tomorrow. Hope my oil pump kept its prime... wish me luck boys! Will keep u posted.
Ever get to it?Boost, not out of the woods yet. Still need to make sure she runs ok. Keeping my fingers crossed. Will finish her up tonight.
Rick,
I actually turned the key about 6 or 7 times and then pulled plug to see if it was soaked. Figured if there wasn't a head on the injector, it would just dump fuel. Correct assumption?
wouldnt hurt...would only take 20minI may just have to! Rick has me thinking that I should pull that injector to verify...
ohh..yikesEasy for normal GNs . I am running a hot air GN with an intercooler. Everything is difficult on this car. The turbo still on the top of the.intake but there are intercooler pipes all over the place. It took me 50 minutes just to get valve cover off.... :-(
