PowerKraus
- Sep 4, 2006
Well, I finally got my AEM wideband installed. So, now I can get a little better tune, than using the stock O2s and Int/BLM readouts. I also connected it to my power logger for logging the readings along with all the other cool stuff, i.e. fuel pressure, 3bar boost etc....
Now GENERALLY SPEAKING what range should I begin with for WOT blasts. And would you suggest two different 'acceptable ranges' for pump gas vs. high octane unleaded. If this is the case, I woud assume, you'd go a little fatter for pump gas.
I am starting with 'low timing'....19 to 21 degrees of timing in low gears, droppping to 17 to 19 in high gear, but think I need more like 25 degrees +/- to realy uncover the powerpotential. Please refer to my 3,600lb car, which set up for 1/8th racing and curret combo noted below:
Stock cubed, steel caps, Stock exhaust manifolds
Mild port on iron heads and port matching
Stock TB and plenum + cold air mod + free flowing exhust (bullets)
Extemder Extreme Rev F, MAFT+ timing control
65lb high impedance and Walbro in tank, old 307...but delivers nearly 70psi with no drop off at WOT runs (but I'll keep an eye on this, it or alky is the next upgrade))
TE63 3 bolt with pte ported .63 housing (the smaller housing, but ported)
9" AC n/l 3,500 stall and big PTE front mount
224 HR cam with highlift (yes overkill for the cubes, but this is what i have to work with)
keeping in touch with tuning of max boost to where you see no knock, and still gain power from increased pressure.....and timing. On pump gas should I be shooting for 10:1 to 10.5:1,or more like 11.5:1 to 12:1?
If you would, help me with a starting point on 93 pumps gas.
Then the big question on how to adjust. Currently all BLM are running great with very little trim changes. For a stock ECM, is it best to adjust by boost pressure, fuel pressure, and timing...Or should I look elsewhere.
Again, I would really really appreciate your opinions on the tuning and 'how to dial it in' as I am not havingany real luck with my searches.
Sorry for the long post, but after nearly 20-years of car ownership, I feel like I have only now accessed one of the most important tuning parameters and respectfully request some help with which to 'fine tune' this buggy. Afterall, she deserves it after over 20-years of reading O2s, knock retard, and BLM tweaking.
much appreciated guys and gals !!!
I humbly bow to the Buick Forum Gods to bless me and to steer thine path to that of Buick righteousness and dominance amongst the pegan flesh of 'flash memory' and soulness mail order speed parts!
My thy knowledge passeth from the mouths of gods to thy humble servant!
