Put a bung in my DP and installed the O2. Set up closed loop parameters of 800rpm low 6000 rpm high, 120 enable temp and closed loop enabled, and there is 0% correction displayed at ANY time. My target AF is 14.1 and actual varies from 13.6 to 14.5. When does it start correcting? I wanna start tuning this thing. How will I know what it wants. I cant watch target/actual and grab VE areas and modify them while I'm driving.
What are "normal" VE numbers for a 231 ci motor w/stock long block? I dont know but it seems I had to make a lot of changes to the base program that comes burned on the unit. And what timing ranges do these things like on pump gas? Is it exactly the same as on a chip? Cuz the chips crank offset is like 24* and this one is 10*. Should the FAST unit be 14* lower than I do on my chip?
What am I missing or overlooking? I KNOW I'm not that close right off the bat...
