No problem. I think it is a good idea to use the largest servo you have available to you even if you don't notice too much of an improvement in shift feel. Since the servo applies clamping pressure on the band to stop the direct drum, a larger servo will apply more pressure, thereby reducing slipping of the band and heat generation. The end result will be a trans that may live a bit longer, and that is always a good thing.
