Are you talking about the pump motor? I have another one of those if thats what your talking about. Could the switch actually cause it to blow a fuse? If so, How? Is it maybe letting the pump run to long? I thought the relay on the pump actually shut it off when the pressure reached a certain hight, Or is that the switch shutting it off also as well as turning it on?
