blue t-type
- Sep 5, 2001
Last year I switched from Blue tops to MSD 50's. I had my RA93 chip upgraded for the 50 psi injectors (I know RA does not like these injectors). Ever since this modification the car is slower. I was consistantly running 12.1 at 110 on 94 octaine pump gas with the blue tops & now the fastest I have gone is 12.5 at 106 mph with the MSD 50's. I know there are people running good on the MSD 50's.
What street chips are you guys running? Please post 1/4 mile times!
I changed injectors because I could not get enough fuel with the Blue tops had base fuel pressure turned up to around 55 psi to run those time posted with no knock & o2's ain the .770 range. I would like the car to run in the high 11's on pump gas.
see signature for modifications.
