What dice wrench for this not while removing tranny
Dhos1
Self-tuning wanna-be
To whomever removed a granny, what size is this not—does it even come off?
It’s in the shaded area, not a very good view here it’s after the threaded portion
Was trying to type fast, many errors but I am curious what size is the nut behind the shadowed portion. Hard to see.
There’s a nut behind the threaded portion and I posted a pic I’m not sure why it’s not showing
I have it a tv and the end of the cable came out, no gear. Is there a tool for this. I wish there was a write up with pictures. The one write up the pics do t show anymore
Did you remove or loosen the bolt next to it? Rotate the retainer downward for clearance? Not sure if that is necessary or not.
I have it removed and the end of the cable came out, no gear. Is there a tool for this. I wish there was a write up with pictures. The one write up the pics do t show anymore
Tv cable is top passenger side forward just above oil pan.
Your pic is driver side rearward
As said above if the cable did not pull straight out you will need to pull the 10 mm bolt to get the speedo gear. 2B18EDFA-6E1D-4C0B-9386-14B9517CCEA7.jpegThis will require more than just a tug to remove.
Sadly there is no good YouTube videos because it’s the easiest part to remove from a transmission when pulling a transmission from a car.
Please tell use you removed the 3 bolts that hold the converter to the flex plate
I didn’t remove them yet, just got the cable out. I’ll go further tommorrow
I’m not at the transmission bolts yet—close but not there yet
