I've been out of the game for a few years, had motor in a local rebuild shop for a yr now & last weekend I found out TA has a alum block w/4.0" bore, so now now I'm looking into that for my rebuild since I'm still on my mechanics waiting list.
List of parts on the car currently:
PTE 62mm GT 1st, gen, journal bearing
gn1 alum heads
212 cam stock rockers
ATR liq intercooler
ATR full exhaust & headers
BGC intake port matched
trans, Janis build with all hardened parts, shift is set to be 200rmp later than stock
Precision multi clutch converter 405336
FAST ECU
HRpartsNstuff rear suspension
Current list of parts intended toward the rebuild motor(before I found the alum block):
3.625 stroker kit(skat 5.970 h beam rods, and JE pistons) from gn1performance
212 roller cam & 1.65 rockers
PTE ??mm CEA BB turbo, size yet to be determined
alky injection
XFI FAST if I can find the money
I know I need to get new pistons & rings, since the stroker kit is purchased for a 3.8", is there any other mods I should or reccomend to do, to make everything make up?
Hoping for 600 wheel hp. I don't know if the mechanic has bought the cam yet, so this sizing might be change able. I have tried a 218/218 cam previously & though it lacked bottom end for cruising in lockup in 4th. People tease me at work, because I shift my daily driver below 200rpm all time, so I guess bottom end tq or turbo spool at low RPMs will be important to me for turbo/cam selection.
I hope to see TA performance & Champion at the Nats next week, maybe do a motor purchase if they stock any. I know they build in small batches & could be long lead time on blocks, so I don't know if I will wait or not. Off-center is what I want, right? Does Bison have a vendors tent at the Nats? I don't know who he is or if he is a vendor. His profile doesn't list a company name.
gn1 alum heads
ATR liq intercooler
FAST ECU
alky injection
