What do u think it will run
boost86
I have a 86 T-type wanting to know what u guys think it will run in the 1/4. and a guess to hp and torque # heres what i have so far
RJC Power plate
LT1 Valve Springs
206/206 cam
TE-44
ESP Front Mount I/C
Tinman Cold air
3in THDP
ATR 3in Single Shot
2800 Stall
Trans go shift kit
Walboro 340/Hotwired
009 injectors
Adj Fuel Pressure Reg
Adj Wastegate
if you set it on kill, if the car will short time,if, if, if, you should see high 11 teens-11 twentys.
what kind of gas and chip what type tires that would give a better idea. i would say 12.0 to 12.5 say your around 300 hp plus and 400 lbs
We have similar combo's, I dont have track times, but you can see my dyno numbers.
