ok guys im redoing the engine since the thrust bearing went so im doing some other stuff to it as well i want to know what you think the combo should be capabel of with some tuning:
combo 1:
te-44
009's
eastern FM
mease DP, test pipe, and hooker cat back
212/212 cam
ported and polished stock heads with 1.77/1.50 valves
forged pistons
block girdle
cold air kit
RJC PP
62mm TB
ported intake
eric shurtz tranny with art carr 3200-3500 stall
28" tall tire
20psi of boost
Combo 2:
same as above but with alchy, 24ish psi of boost and more timing
combo 3:
same as abot but with a t-60 and 50lb. injectors and 20psi
Combo 4:
same as 3 but on 24-25psi, alchy, more timing
i might be forgetting someting in here im just throwing this out to get an idea and if i missed anything in here to see waht you guys think
combo 1:
te-44
009's
eastern FM
212/212 cam
forged pistons
block girdle
cold air kit
RJC PP
62mm TB
ported intake
28" tall tire
20psi of boost
Combo 2:
combo 3:
Combo 4:
