85 Riviera
- Aug 19, 2002
Trans is a 325-4L with a D5 converter (which is basicly a FWD verson of the 200-4R except the pump is more like the th350).
The sound I am getting can only really be heard while its in gear. And under a slight load. It sounds kinda like a ticking sound of a really bad lifter, except its coming from the trans.
Its best heard at speeds about 35 to 45 with a steady cruise or a little more, but can be heard at any speed as long as the engine load is slight and the RPM's between 1600 to 2200.
I can also be heard if I have someone put the car in drive, hold the brake hard and give the car throttle (against the stall).
It does not tick in N or P... and it doesnt do it at idle. Im confused
Anyway got any ideas?
