What does this SOUND like?
85 Riviera
Trans is a 325-4L with a D5 converter (which is basicly a FWD verson of the 200-4R except the pump is more like the th350).
The sound I am getting can only really be heard while its in gear. And under a slight load. It sounds kinda like a ticking sound of a really bad lifter, except its coming from the trans.
Its best heard at speeds about 35 to 45 with a steady cruise or a little more, but can be heard at any speed as long as the engine load is slight and the RPM's between 1600 to 2200.
I can also be heard if I have someone put the car in drive, hold the brake hard and give the car throttle (against the stall).
It does not tick in N or P... and it doesnt do it at idle. Im confused :confused:
Anyway got any ideas?
I would have said CV joints, except you hear it at stall? Does it tick all the time during stall? Drive chain maybe?
I thought the same at first. So I got under the car and checked the torque convertor bolts and flywheel. Both checked out to be ok. I was hoping to find loose bolts :confused:
