On the rears, you also need to make up shock relocation brackets. I made mine from a 2" square tow hitch. I cut off a piece about 2"  long and then cut it diagonally from corner to corner, making two right angles, drilled it and mounted it to the rear and used the other angle to relocate the shock as shown. I have since drilled and threaded an additional hole to pin the bracket in place, approximately midway between the anchor bolt and the upper corner of the bracket.
