Good chance that there is tooo much silicone between the rear of the cap and the block which tipped the cap forward and left the bearing surface too tight in the front and to loose in the back from not being square. Good chance thats your leak problem also! Just my 2 cents!! Mike
The silicone was causing it I spun the top bearing out and it is worn on the other side so because this cap was tweaked, it ended up tweaking both of The bearings. So I will throw a new set there tomorrow. Should I chance all the main bearings or just the rear one.
