SignUp Now!It has 566 then under it it has 280150967 I thinkif they are dark blue on top, with black bodies, then they are most likely what we call "Blue Tops" around here...... 36 lb/hr from a Furd T-bird SuperCoupe if I remember correctly.
Do you know what chip is in the car?
Bob
566 under it is 280150967Do they have blue tops or are they all blue? There should be numbers molded into the tops of the injectors somewhere to identify them.
So that is stock or notthat would be the 36lb BlueTops...
Bob
What is recommended for a upgrade ?So that is stock or not
jk kelly said:What is recommended for a upgrade ?
High 11s low 12s is my goalfor modest horsepower goals, the 36's run really well.
What are your intentions with the car?
B
