TexasT
Texas, Where are you from
- Sep 10, 2002
You going to noble?
Sent from my HTC PH39100 using Tapatalk
SignUp Now!This was TURBOBUICK first encounter with the 2004r dual feed concept.
http://www.turbobuick.com/forums/th...t-shifts-ok-while-cruising.88979/#post-612468
For years the dual feed mods evolved to what they what has become my standardized version.The CK separator plate and leaving off the center lip seal and sealing ring. This works well regardless of 3-2 mod or not and regardless of valve body calibrations. The hole sizes of the present holes and the omission of others have allowed this. Occasionally I hear about tie ups when used with a certain aftermarket servo,but the installation of our 3.005" set up instantly corrects it. What I consider to be my most significant contributions to calibrations effective for high horsepower are the dual feed,the 3-2 control valve mod and the properly specked servo release spring.This is where I found the biggest improvements in the hydraulics realm.Most of my battles with the hydraulics are won at this point in the game. There are always problem children, however. It is great to see that a majority of my modifications are now mainstream 2004R building practices.There are many others out there who have improved the transmission as well,with due respect, but I believe I have perfected the areas I set out to conquer.You still using the orificed cup plug in the direct feed in the case as referenced in that thread? Or does the 3-2 control valve mod eliminate the need?
I, like many others, truly appreciate the time that ALL of you pros put into coming on here and helping all the hobby builders get this stuff right. Saves a lot of trial and error
I believe transgo kits now have a mellowed out version of the dual feed mod that combined with reduced line pressure and smaller feed orificing ,keeps the drum alive but above 300 horsepower the need to have a specific size hole between the band knock off and direct feed has proven to be mandatory. It is also universal whether it is a 2004r,c4 c6 or a torqueflite. The overlap shift, the engineers dreaded task of keeping it clean at all throttle angles,engine loads, axle ratios and vehicle weights. The 3-2 control valve, the engineers attempt to control the release of the third clutch on a 3-2 kickdown, introduced a unique set of issues on the 2-3 upshift (flaring) etc. due to the infinately variable orificing of band knock off oil under varied operating conditions. It had to go, and I got rid of it.I'll say something that comes to mind here......this is probably the best tech thread I've read here in a long time! Glad to see some good info being put out there.
How many guys have dual fed a stock drum and have it last?
I have had a few transmissions come thru here with the kit and converted them over to my method.Not because I didn't trust it, but because I was not interested in figuring out how it worked and then making the decision if I was comfortable with it. Trans go's tech team employs some the brightest individuals in the business in my opinion.Did you ever acquire one of those kits to see how they did it? Irreversibly modifying the case partitions to truly dual feed both the direct side and the reverse side passage thru the center support bolt, no blocking of the bolt hole. Seems like a lot of wasted effort. I snagged a new HD-2a kit off eBay cheap just to satisfy my curiosity. Probably never use most of it.
At least the new kits acknowledge that not all vb codes are the same.
