What is the CCCI fuse?
unplug harness to coil, turn key on to see if fuse blows, if it doesnt you may have a shorted module or coil pack, if fuse blows then yes its in the wiring, probably something close to a heat source melted.
Appreciate it. I will try that tonight when I get home.
For future reference, I believe it stands for Computer Controlled Coil Ignition; other post's trouble shooting sounds right to me. Good luck!
Makes sense. Thanks for the info. I found one of the wires pinched in between the module and the coil pack. Amazing how many problems that can cause. Fixed now. :D
