I can tell you from a very expensive experience that do not torque them 80 ft-lbs with the moly lube unless you feel like using heli-coils. Also there are 3 sizes in case you didn't realize it. My heads are torqued down 70 ft-lbs with the lube using stock GM gaskets and I have been running 19-21 psi on 93 for 2K miles and have no problems. Don't go crazy with the torque because those specs are recommended for a reason. The lube is very slippery even under pressure and will obviously clamp the head down properly. "thinking" is good, but that will not supersede the tons of testing and experience ARP has.
