what is the fastest MPH that anyone has gone with stock injectors?
Well I can't find a time slip anywhere. I do remember that day that I had just put in a new 02 sensor. Not heated. At high boost it always shows low 02's. Right now I'm running a mixture of xylene and 93 pump gas with 18-19 lbs of boost and the 02's are 740's at the top of 3rd. This is with a JC93 chip. With 93 pump gas and boost around 16psi the 02's are around 800mv. Brand new plugs and wires. I haven't run any race gas since I replaced the 02 sensor. R.B.
Maybe my stock injectors are just wore out! Will the low 02's effect the performance of the car even with no knock??? R.B.
well-
if it was really starved for fuel, wouldnt it knock :)
you could buy a egt meter from SMC, and see if its getting lean on the top-- my guess is with 116 octane, and only 103mph, ITS VERY RICH!!
for instance-
my stock rusty piece of crap 86 t-type, last time to track, pump gas, radials, stock injectors, thrasher chip, 340 pump, went 13.40's at 103 - and its tuned pretty good-
hth-
you have ground issues, and need to lean it out, even though the crappy 02 says its lean-
please buy a egt meter and tune for zero knock
I really appreciate all the help. Sometimes it's mind boggling!!!!!!!!
oh and tune for 1550 degrees at the top end- perhaps right through the traps
Hey I found a couple of time slips for that day!
60' 1.808 1.841
330 5.212 5.244
1/8 8.113 8.153
mph 84.34 83.86
1000 10.649 10.698
1/4 12.811 12.865
mph 103.41 103.36
What do you think? R.B.
60' 1.808 1.841
330 5.212 5.244
1/8 8.113 8.153
mph 84.34 83.86
1000 10.649 10.698
1/4 12.811 12.865
mph 103.41 103.36
i assume both are from your car
take the 1/8th mph to the 1/4 mph 19.5 isnt really that good when these cars are set on kill, { race gas and race chip}
it should be above 22 with race gas and a race chip
does your car have a lock up convertor? are you locking it?
what do you guess the cars weight with you in it?? you a big boy? :)
good sixty foots, but the 1/8th times arent that great for 116 octane, how much knock do you get when your at the track?
how many miles are on the car?
HTH
Lock up is built into chip. Car weighs 3460 without me.(+200) 0 knock. 90,000 miles. Original valve springs.
