Aug 29, 2005 #1 S soundguy New Member Joined Jun 6, 2005 Messages 197 found this connector sitting loose toward bottom of engine below turbo. Any idea what it is for? Attachments IMG_0439b.jpg 78.1 KB · Views: 96
Aug 29, 2005 #2 I III'S 87 GN Active Member Joined May 19, 2002 Messages 869 soundguy said: found this connector sitting loose toward bottom of engine below turbo. Any idea what it is for? Click to expand... factory oil pressure switch
Aug 29, 2005 #3 S soundguy New Member Joined Jun 6, 2005 Messages 197 where would I find the connection? couldnt find anywhere to plug it in.
Aug 29, 2005 #4 I III'S 87 GN Active Member Joined May 19, 2002 Messages 869 soundguy said: where would I find the connection? couldnt find anywhere to plug it in. Click to expand... you won't if you now have a gauge instead of the light ! :frown: it would be on the front pass side lower part of the block.
Aug 29, 2005 #5 S soundguy New Member Joined Jun 6, 2005 Messages 197 ah, ok. Yes there's a guage in it now. Guess I can probably cut it off back in the harness to clean up the cables.
