- May 28, 2001
Dr side header is cracked?? Sound comes thru the firewall near the rear of the engine? B4 you tear it down, fix the cracked header.
A couple other places to look.
Take the belt off, and start it.
Rod brg? Pull each plug wire, one at a time, and see if the noise changes.
If you plan to pull the engine, anyway, take the converter loose, push it back, start the engine. Cracked flywheel?
