what is this?
Joeld
Looks like i may be missing either a hose or cap?
Looks like electric vacuum valve
Wastegate solenoid vent. Originally had a tiny filter and most are missing
Thank you
Does the filter get blown off?
I will look for replacement
Joel
Looks like you also have the stock breather on the end of the valve cover. This set up allows oil to enter the intercooler. If you haven't removed it foe cleaning in a number of years you very well may have a pint or more of oil in the intercooler. Most of us go to an open element breather in that spot.
Thank you
Yes intercooler never cleaned ever
I will pull the intercooler this weekend
How do i remove the breather? Do i need to pull the turbo?
Joel
No turbo removal necessary.REmove tube and old filter.Gbody and others sell a new breather with a rubber cap.Cap goes on turbo bell and breather goes where other breather went.Maybe a good idea to get a new breather rubber grommet just in case..
Thank you
Joel
The breather just pulls out. Remove the little shield and pop a new K&N open element breather. No need to remove the turbo.
